Huawei P7 does not boot
Hello Guys,
I have a problem:
A friend of mine has a Huawei ascend P7, but it doesn't boot anymore.
The only thing it does is flashing it light in this order: red 4x, green, red 4x, green and so on.
When I googled it I found out that it probably has to do with either the BIOS being broken or Android being broken.
She tried recovering it with the "recovery mode"(volume down button) but it didn't do anything.
Anybody got a solution? Maybe uploading a previous version via sd (if possible?)
Thanks in advance,
Byonnem
(No I'm not new to the forum, my other account has been blocked due to the server breach, and I can't get it back)
If you phone isn't bricked then you will need to use adb to get back into the system. Boot your phone into fastboot if possible and then hook it up to your computer via usb. Once you've done that get the correct drivers and an adb bridge working. Check to see if your adb bridge can see your device and if so you will probably need to flash it back to stock firmware.
