Well I got some new headphones(HD 598) and my computer can't drive them well (I can hear sound but its pretty bad quality. I was just wondering what will be the best sound card I could get for my system because my computer is pretty old and there are probably some hardware limitations. I was also thinking of improving my cpu and getting some gpus.
PC Specs:
Dell Vostro 220
CPU:                  Intel E2200 (2 cores, 2.2Ghz)
Motherboard:     G45M03
Ram:                  4 GB (2GB inItial but upgraded to 4 GB)
Power supply:    300 watts
No graphics card
No sound card
Thanks for all the replies!
https://linustechtips.com/topic/500594-need-sound-card/
one of the xonar ones
the DG is legacy PCI so that might work for your board
https://linustechtips.com/topic/500594-need-sound-card/#findComment-6684481
so are there any hardware requirement or can i just grab anyone
hardware requirements are on the website
you just need an ok cpu, some ram and storage space
just make sure you buy a PCI or PCIe card depending on what your motherboard has
https://linustechtips.com/topic/500594-need-sound-card/#findComment-6684633
