Strange video problem
Go to solution Solved by SirDucksallot,
Thats Artifacting,lets get the easier things out of the way first!
1)Try changing your monitor cable to an other one.
2)Try a diferent monitor.
3)See if the card is overheating.
4)If ths continues after all you've done,its probably a deflective card,go ahead and contact your manufacturer and request RMA.
5)Guy above me suggested something I didnt think of,you could try that too.
Hello I'm having a problem with my new PC that I build, all the color are very weird and there is a lot of "strange" pixel that change with the image,and they aren't always in the same spot.
My spec are:
  • Windows 7 Ultimate 64 bit
  • msi b85-G41 (BIOS version 2.9)
  • Intel i5 4690k
  • SKILL Ripjaws X Series 16GB (2 x 8GB)
  • ASUS STRIX - Nvidia GeForce GTX 970, OC, 4 GB
  • Seagate Barracuda ST1000DM003 Hard disk
  • EVGA - 500 Bronze Power Supply (500W)
  • flatron M227WD (Screen connected with hdmi)
http://i.imgur.com/7GDB51C.jpg?1
http://i.imgur.com/FIPr0qc.jpg
http://i.imgur.com/yF2QBSD.jpg?1
http://i.imgur.com/LZd26ZX.jpg?1
http://i.imgur.com/ZxfQpju.jpg?1
https://linustechtips.com/topic/500342-strange-video-problem/
That's called artifacting. Reduce any overclocks you may have.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/500342-strange-video-problem/#findComment-6681472
Could be the RAM. I had the same thing happen to me with my laptop due to a failed/faulty stick of RAM
System Specs
  • Gaming/work PC:
    • Processor: Intel Core i7 4790k  @ 4.5Ghz
    • Memory: 32GB RAM (Corsair Vengeance)
    • Graphics: ASUS GTX 980 Ti
    • Motherboard: Gigabyte Gaming 5 Z97
    • Storage: 3x 1TB Samsung SSDs (Not in RAID) & 1TB WD Black HDD
    • Case: H440 Designed By Razer
https://linustechtips.com/topic/500342-strange-video-problem/#findComment-6681544
Edited by SirDucksallot
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
https://linustechtips.com/topic/500342-strange-video-problem/#findComment-6681549
It started again with the artifacting  :(
Follow the rest of my steps.
https://linustechtips.com/topic/500342-strange-video-problem/#findComment-6686852
Ok i tryed to plug and unplug the hdmi and now it work well but i'm not sure it's resolved because it happened again that for 30 min it was ok and after started again
I will keep you update if it happen again tonight thanks a lot for now :D
Try running off of your on board graphics (plug monitor into motherboard), and see if the problem persists.
If this solves the problem, then RMA your graphics card.
Hope this helps :)
https://linustechtips.com/topic/500342-strange-video-problem/#findComment-6687360
After several hours it still works =D I consider this fixed thanks to all for the help , awesome forum :D
Dont forget to go to the post that helped you and click Marked As Solved!
lol,didnt see that you did,ignore this
https://linustechtips.com/topic/500342-strange-video-problem/#findComment-6697062
