Hey there guys, I only JUST bought an Nvidia Shield Tablet, and I think there's a battery issue! I set it on airplane mode, and only enabled the wifi, with about 20% brightness. I'm currently doing nothing, and at the battery seems to be draining at 1% per minute!! At 78% doing nothing, it says I have 17 hours left?? On another forum, I saw a picture where a guy had 19 hours more when his was at 41%! Please help, I have reformatted the device twice!
https://linustechtips.com/topic/500154-shield-tablet-battery/
wait wasn't there a recall on the shield, something to do with battery ?
2K POSTS  :D  :D  :D
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/500154-shield-tablet-battery/#findComment-6679322
2K POSTS  :D  :D  :D
CONGRATZ!
But yeah, there was a recall, for Y01 batteries. Mine is the B01 battery, which is not included in the recall program. Damn, I legitly need help!!
https://linustechtips.com/topic/500154-shield-tablet-battery/#findComment-6679403
Most reviews I've seen about the Shield tablet claims that it has sub-par battery life, at least when compared to something like an iPad or Samsung tablets.
The software upgrade to lollipop or marshmallow might have exacerbated the sub-par battery problem.
Might just have to wait it out, or try factory resetting.
https://linustechtips.com/topic/500154-shield-tablet-battery/#findComment-6684506
I have factory reset twice!
If you think there is an issue with you tablet contact the support or retailer and tell them about it.
I don't know if it's normal yet though!
https://linustechtips.com/topic/500154-shield-tablet-battery/#findComment-6684632
Damn it!! I only just got this tablet, and I bought in Malaysia, country which Nvidia has no support for, what do I do!?
se if your retailer can RMA, or exchange for a new one. Tell them the battery is defective.
https://linustechtips.com/topic/500154-shield-tablet-battery/#findComment-6684838
Not a retailer, just another person, He isn't replying at all..
RMA that thing... This is what my shield tablet is showing.
Fudge, I can't! Damn this sucks bad
https://linustechtips.com/topic/500154-shield-tablet-battery/#findComment-6685003
