"Cleaning" my pc
Go to solution Solved by Samdb,
Ccleaner is a good program to use.
Hi everyone! So I just want to know if I should be cleaning pc. I don't mean cleaning the hardware of dust, but I mean making my pc run faster and stuff. I have heard of "defragmenting". And other things. Is there anything specific I should be doing often to keep my pc running fast? Are there programs I can use to "clean" my pc? Also any tutorials you could link would be helpful.
EDIT: Also I wasn't sure where to post this. So sorry
Nzxt Phantom 410 - I5 4670k stock - 7950 vapor x @ 1000mhz/1250mhz - Msi Z87 G45 - 8gb Corsair Vengeance pro 1600mhz - TX650 - Benq XL2420t - Blackwidow Ultimate 2013 - Deathadder 2013
https://linustechtips.com/topic/49934-cleaning-my-pc/
CCLEANER is what i use
Ok cool. I'll be sure to check that out later. Thank you both
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-665394
+1 on CCleaner. Great tool to clean files and fix registry issues safely.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-665395
cclearner once a week for me
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-665401
http://www.dban.org
Only cleaning I every do involves this :D
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-665527
i don't trust CCleaner, I tried it once and then my computer stopped being able to install windows updates. I also had some other problems I don't remember but I eventually just reinstalled the OS. Do it at your own risk. Maybe I did something wrong but I'm probably not going to try it again.
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-665856
Ccleaner, use both the file cleaning and registry options... And also I recommend Auslogics Defrag, for defragmenting, its very fast!
CPU: AMD FX 6100 Stock - MB: Asus M5A97 EVO - RAM: AMD Memory Entertainment Edition 2x4 GB 1600 MHz - PSU: Topower 650W NANO - SSD: Samsung 840 120GB - HDD: Seagate Barracuda 500 GB 7200 RPM - GPU: Sapphire HD 7770 Vapor - X OC - CASE: Aerocool Strike - X Advance (Red/Black) - OS: Windows 7 Ultimate x64
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-666186
If you want to go deeper in cleaning, Bleachbits is another program you can try. Please be careful when using this program. It can easily remove something you need if you're not careful. For defragging, you can use Puran Defrag and Auslogics Disk Defrag(programs that I remember besides the default program).
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-666304
CCleaner and Defragler. Just don't defrag ssd. Good allaround soft is Advanced Windows Care. I've been using it for years and even free version does enought. I have pro now and I'm very satisfied to everything it does.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-666950
CCleaner once a week on it's default options :) also has a nice start-up manager for making boot-ups even faster.
Main PC: i7 3770k @ 4.2Ghz Corsair H100i V2 | MSI GD65-Z77A | NZXT Tempest 410 Elite | MSI 1080Ti Gaming | Corsair Vengeance 4x4GB @ 1600Mhz | 2x Samsung 850 EVO 250GB | Seagate 2TB | Corsair RM650x
https://linustechtips.com/topic/49934-cleaning-my-pc/#findComment-666969
