do my system has "clock tuning capabilities" ?
Go to solution Solved by W-L,
-SNIP-
If your talking about overclocking, that CPU has a locked multiplier so you can't overclock it in any meaningful way.
Specs
CPU i5-4460
Motherboard MSI Gaming 3 Z97
RAM Corsair Vengeance 8GB 1600MHz
GPU MSI GTX 960 Gaming 2GB
because i want to submit my validation
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/499305-do-my-system-has-clock-tuning-capabilities/
thanks man
thanks man
If you plan to upgrade to a K series like a 4690K or 4790K down the line that motherboard does support overclocking feature though. If not you can save a few bucks to get a H97 board which doesn't have the overclocking built in.
