I want to build a budget PC for just for fun creative work, after trying to render with blender using an Intel 5500 graphics chip, I decided I needed a PC with a real video card. I am looking for under $500.
  • At least 8 GB of RAM
  • At least an Intel i3 chip with haswell (if not skylake)  technology
  • At least a 128 GB SSD
  • At least a 1 TB HDD
  • At least 4 USB 3.0 Ports on the motherboard
  • At least a DVD reader & writer
  • Windows 10
I am mainly going to use this computer for web browsing, screen recording while playing Minecraft, image editing, video editing, blender, illustration software, and publishing software.
Got an Android, never going back to apple again (notice I spelled apple with a lowercase and Android with an uppercase)
https://linustechtips.com/topic/499304-build-for-creative-work/
For under $500. Good luck with that considering the parts you want.
TheGrim123321
CPU: I3-4170Cooler: Hyper TX3Mobo:Biostar B85MGMemory: G.Skill Ripjaw 2x4GBStorage: Barracuda 500GBGPU: Zotac GTX660Case: Fractal 1100PSU: Evga 500WMonitors: FHX2153L 21.5"│V193WEJb 19"Keyboard/Mouse: CMStorm DevastorAudio: MonoPrice 8323Microphone: BlueYeti BlackoutOS: MSX(Win10) Quote me or @TheGrim123321 to get my attention.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670460
You've gotta be kidding me, all that plus a Wacom tablet for under $500?
I think you need to get some handle on what parts actually cost, because you're a little out there.
That said:
Do your programs favor Nvidia or AMD?
Do you need Windows 10 factored in? That alone is 1/5 of your budget, and if it's for work I would not get it from Reddit/G2A etc.
Where do you live? The $ sign is used by many countries.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670486
@Maximoose follow your posts.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670487
Notice I said some of this stuff would be nice
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670516
Even your main points are a little high.
You didn't answer a single question I asked to help the build.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670520
Sorry, I live in the US and My programs don't favor anything in particular although Nvidea would be nice, it's not professional, although I wouldn't want a copy off of reddit, because given the way windows is going, I want to be able to upgrade to the next version for free. I just changed my original post from a skylake CPU to at least a Haswell CPU
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670543
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard  ($62.98 @ Newegg)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($159.99 @ Newegg)
Total: $493.01
Generated by PCPartPicker 2015-12-05 00:26 EST-0500
ok i couldetn get the main points... but you want a ssd for under $500 with a current gen cpu thats... impossible unless you dont want storage space, or a good gpu.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670545
Total: $399.79
Generated by PCPartPicker 2015-12-05 00:29 EST-0500
With $100 left, get a second hand 79-- Series AMD card that was bitcoined before.
And also your wacom tablet for the rest of the money and more.
This is probably the only choice considering i was forced to even put a cx inside.
If you are studying, use DREAMSPARK for your windows keys.
There are free there.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670556
Do you require a screen?
Im not really sure what a wacom tablet is, it is a drawing monitor i guess.
So you wan't the output display to be on the wacom tablet?
 I do not require a screen. a wacom tablet is like a trackpad except with a stylus for it to make creativity easier on a desktop pc (Wacom is a brand):
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670557
Oh i see, but i have seen version of it that has a built in monitor, guess that is not what you are looking for then.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670567
CPU: Intel Core i3-4370 3.8GHz Dual-Core Processor  ($142.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($42.98 @ Newegg)
Video Card: MSI Radeon R7 370 2GB Video Card  ($108.98 @ Newegg)
Power Supply: EVGA 400W ATX Power Supply  ($25.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.88 @ OutletPC)
Total: $511.67
Generated by PCPartPicker 2015-12-05 00:34 EST-0500
ehh $11 over after rebate, but I would go a differnt rout if I knew this is what I was getting...
i for got to add windows to the first one...
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670591
Total: $493.01
Total: $399.79
I changed what I wanted above
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670598
Here's why what you ask for is so hard. Here's what I'd go with, with the cheapest reliable parts I could find.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($112.89 @ OutletPC)
Motherboard: Asus B85M-D PLUS Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($29.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($59.00 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($29.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Total: $471.71
It still lacks a video card.
I wouldn't bother with a fully modular power supply, semi-modular is just as good; you need the CPU power plugs regardless of what you do with the rest.
Total: $493.01
You're also missing Windows...
Total: $399.79
CX *shudder*
Nice build though.
I'd never recommend a card used for mining. You simply don't have to go that route. I picked up my 7970, not used for mining, for $50. You just have to hunt for good deals.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670610
So before I posted this, I tried my hand at choosing parts on pcpartpicker.com. I got it to $800 (Including the OS) and I figured if anyone could get it lower without compromise it was the people on linustechtips.com, so I posted this topic.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670618
Total: $471.71
CX *shudder*
Nice build though.
I cant delete posts... I reposted this...
Total: $511.67
Gosh does anyone look all the way to the bottom of the page...
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670630
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($89.99 @ Amazon)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($62.98 @ Newegg)
Total: $498.77
Generated by PCPartPicker 2015-12-05 00:58 EST-0500
everyone will hate this but I would get this, but with more used parts, and a better gpu. If I only had $400 to spend on hardware.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670717
You posted that over 20 minutes after I quoted your post.
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670779
then how is my post above yours... but I can see that you might have quoted it and then sat there doing something else.... I do that alot
https://linustechtips.com/topic/499304-build-for-creative-work/#findComment-6670800
