My friend was complaining about Random BSODS, so after looking at the minidump in WinDBG, I noticed that Avira's Scanning Component was causing the system to sometimes crash.
Looking in the Event Log, I noticed an irregular pattern of crashes and decided that I would run the system file checker and run Memtest86 to be thorough.
I received the following errors after running memtest:
I get the same errors using both the original DIMM and a known good DIMM in both slots on the motherboard.
More details can be provided if requested, but I am currently at work so if you would like the exact motherboard model, I will provide it some point later on today.
Thanks for any help provided!
https://linustechtips.com/topic/498791-memtest86-same-errors-different-dimms/
I actually had problems with errors in memtest earlier this year as well. Problem with memtest is that errors in this test may be related to faulty RAM-slots, or faulty RAM or a faulty CPU. However I was unfortunately not able to find any info on how to distinguish the different errors and find out the right component. I would highly suggest testing the RAM on a different board and other RAM (tested and well working) on the initial board. Really this is the easiest way to go about it I would say.
Actually for me (which was a bummer) both the slots as well as the ram ended up being faulty.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
Could be the ram settings, it might not be picking up xmp correctly so disabling it and going down to the standard speed with default cas/ras/etc might resolve it for both sticks. If it doesn't then there is a decent chance the motherboard is suffering a weirs failure (of is never the CPU)
