Hey guys let me hear what you think thats wrong with my GPU
I hav tried to change cables and screens so its none of them.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/498267-gpu-problem/
What GPU do you have? Looks like it's about to die.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658913
and its not only in csgo it does this. It only happens sometimes
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658914
ASUS GTX 780 ti
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658918
When you mean sometimes, does it happen on the desktop too or out of game? Do you have another GPU you could test in your pc like a really old one lying around somewhere. If it stops doing this then it is your GPU for sure. Also, you could test your pc with a different monitor if you have one and see if that makes a difference (I highly dought this point will work but it is still worth a shot)
IT Manager working in the Education sector.
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658936
Welcome to the wonderful world of artifacting, you have two choices.
1. RMA GPU to manufacture.
2. Downclock it until it goes away.
i have sent it back to the place i bought it from, and i tried doing that i downclocked it to under what a normal 780 ti has in clock speed, but after 2 weeks i saw it again
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658940
Option a : rma it
option b: overvolt it.
Option c:downclock memory
option d :downclock core
This is called artifacting, and is typically met when a gpu is not stable.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658945
I have tried it on one of my old monitors, and yes it happened one time on my desktop but that was really fast.
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658953
Option a : rma it
i have tried  c and d so now i sent it to rma at the place i got it from
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658961
Send it back to the manufacturer not the retailer.
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658963
it's too late but the retailer works really close with Asus
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658966
Ok, well now you need to test it with a different gpu. If you have one then use it but if you dont then try and get a friend to lend his pc's gpu to you for a while so you can figure out if your gpu is the problem
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658969
i have tried a 390x in my pc and that works fine
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658972
this is just really weird, this is the second 780 ti from asus that broke down on me
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658981
Ok, then it is your GPU for sure that is the problem. I have a question though... Have you everhad your current GPU overheat? This could be the cause as I have a friend where his gpu overheated and this is the same problem he had. It may be your drivers too, you could try to revert back to older drivers from your manufacturers website.
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6658991
the max it got to was 75-77c, i would not call that for overheating
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6659056
and yeah i have tried the drivers
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6659059
I guess that i just have bad luck in graphic cards :unsure:
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6659099
Has your card overheated?
no max i have ever seen is 77 degree Celsius. Yeah i try to keep my system "cold"
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6659128
thats 170.6 fahrenheit
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6659159
Hey, Are you still looking here?
This might be due to a bad power supply making the cards go wrong: a bad one can supply irregular current to your GPU and even surge it which might damage them permanently. What PSU do you have? and have you had any of your GPU's do this on you before? Is this the first power hungry GPU you have had and is it the first one to go wrong like that, after a short amount of time.
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6687723
I dont think that my AX860i is the problem, and I got my money back
https://linustechtips.com/topic/498267-gpu-problem/#findComment-6709519
