Hello smart people of the LinusTechTip Forums!
After lots of google searching (maybe not enough), I have failed to find the value I need to change in the "Kepler Bios Tweaker" to increase the Voltage Offset of my card. Here is some of my card information
Stock (as came with laptop G46VR)
GTX 760M
Base: 615MHz, Boost of 715Mhz
Mem: 1750MHz x2
Base Voltage: 0.900
Temp: 63C
First Stable BIOS Flash (tested for 1 month)
Base: 849Mhz Boost of 915Mhz
Mem 2925Mhz x2
Base Voltage 0.900
Temp: 70C
Stable Overclock Current (currently testing using nvidia inspector)
Base: 1110Mhz Boost of 1250Mhz
Mem: 3100Mhz x2
Base Voltage of 1.025
Temp: 81C
So obviously I had to raise the voltage to get it this far but whatever I do in the Kepler Bios tweaker I can't get the voltage settings to change at all on the card. everything else works great and the bios flash keeps my settings. I want to flash the BIOS because I don't want to keep using inspector to overclock. There are so many voltages under the Voltage table an none of them are .900v lol
P16
P00
P05
P08
CLK01-25
I'm not looking for a step by step but just a nudge in the correct direction. Below is a screenshot of my current inspector screen. (which has been stable for 15 days of various games and compute benchmarks (I use double precision benchmarks to validate my overclock)
Not final clocks, still playing. yes too much voltage but still finding a good medium
https://linustechtips.com/topic/497519-kepler-bios-tweaker-voltage-offset/
