Best 24" monitor for <$200 AUD
X1XNobleX1X
Hello forum members,
I'm in need of a new monitor that will be used for architectural design, so higher resolution and colour reproduction is not needed, but would be good (1200p maybe).
Anything under <=24" would be good.
The budget is $200 AUD , but if there is a monitor above this price range that is worth it, I can adjust the budget to $250 AUD.
Thank you, although a know quite I bit about computer components I know nothing about monitors, which are good or bad. I normally go for DELL but as they're in the $250-300 range, they aren't applicable..
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Anyone?
can't really go wrong with any monitor if its just for architectural design
https://pcpartpicker.com/parts/monitor/#X=0,15848&W=2000,2400&sort=d6&page=1&r=192001200,192001080&m=3,143,8,139,13,20,129,32,35
pretty much everything that has stars is going to be good
i would recommend the
Acer H236HLbid , if you like glossy / reflective screens
Asus VX238H , if you like matte / non-reflective screens
if you really want a 1200p display the prices go up, but i am not from australia so i am just basing my prices off of AUSD to USD conversions.prices on monitors could be really jacked for all i know over there.
attempted to check the Australian amazon.au.com , but found they only sell books and apps i guess???
