Sorry if this is in the wrong section or if I'm not posting right but I need some help QUICK.
How come this is outputting "[Function]" instead of what I want the console to print?
Here's the code and the website that I've been using to work on it is http://repl.it
var userChoice = prompt("Do you choose rock, paper or scissors?");var computerChoice = Math.random();if (computerChoice < 0.34) {  computerChoice = "rock";} else if (computerChoice <= 0.67) {  computerChoice = "paper";} else {  computerChoice = "scissors";}console.log("Computer: " + computerChoice);var compare = function (choice1, choice2) {  if (choice1 === choice2) {    return console.log("The result is a tie!");  } else if (choice1 === "paper") {    if (choice2 === "rock") {      return console.log("paper wins");    } else {      return console.log("scissors wins");    }  } else {    return console.log("paper wins");  }};var compare = function (userChoice, computerChoice) {  if (choice1 === "scissors") {    if (choice2 === "rock") {      return console.log("rock wins");    } else {      return console.log("scissors wins");    }  }};console.log(compare);
CPU: i7 2600k @4.2GHz GPU: GTX 660 Power Supply: EVGA SupernovaNEX 750W 80+ Bronze RAM: 32GB G. Skill Ripjaws X
https://linustechtips.com/topic/497147-javascript-problem/
} else {
    } else {
  } else {
    } else {
Because you are logging a function:
Also please wrap your code in code tags
https://linustechtips.com/topic/497147-javascript-problem/#findComment-6646445
Sorry it's my first time posting here. I get what you mean by logging a function but I haven't found any solutions that make sense to me...
https://linustechtips.com/topic/497147-javascript-problem/#findComment-6646455
Right so you have this piece of code:
Here you are defining compare as a function.
Then you are using console.log to log the variable compare to the console. This will cause the function to be logged as it is stored.
https://linustechtips.com/topic/497147-javascript-problem/#findComment-6646498
You can't return a console log. When you call console.log it immediately writes the given string to the console and has no return value, so returning it will not do anything.
Also, compare has parameters and in your current call to it you do not pass any to it.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/497147-javascript-problem/#findComment-6646627
var userChoice = prompt("Do you choose rock, paper or scissors?"); var computerChoice = Math.random();if (computerChoice < 0.34) {  computerChoice = "rock";} else if (computerChoice <= 0.67) {  computerChoice = "paper";} else {  computerChoice = "scissors";}console.log("Computer: " + computerChoice);var compare = function (choice1, choice2) {  if (choice1 === choice2) {    return "The result is a tie!"; //Return returns objects like strings and integers, console.log does not return any value, so it would return "[Function]"  } else if (choice1 === "paper") {    if (choice2 === "rock") {      return "paper wins";    } else {      return "scissors wins";    }  } else {    return "paper wins";  }};var compare = function (choice1, choice2) { //Changed to choice1 and choice2, which are parameters  if (choice1 === "scissors") {    if (choice2 === "rock") {      return "rock wins";    } else {      return "scissors wins";    }  }};//Try to combine the above two functions, to do this, simply combine this as an elseifconsole.log(compare(userChoice, computerChoice)); //Inside the parentheses, we pass two parameters to be compared, these become choice1 and choice2 in the compare function.
http://www.w3schools.com/jsref/jsref_return.asp
Try the JavaScript course on codecademy.com, it goes over all of this and describes it really well.
˙ǝɯᴉʇ ɹnoʎ ƃuᴉʇsɐʍ ǝɹɐ noʎ 'sᴉɥʇ pɐǝɹ oʇ ƃuᴉʎɹʇ ǝɹɐ noʎ ɟI
https://linustechtips.com/topic/497147-javascript-problem/#findComment-6650968
