how to fix CPU Fan Error
Solved by runit3,
On all ASUS boards you need to disable CPU fan monitoring. The "monitoring" heading should be available from the BIOS home screen. Click it, then hit the toggle menu next to CPU fan monitoring and choose disable. There may be some variation on this, it could be available in the Q-fan section as well. (I'm not home ATM)
popularlion ·
Posted in Troubleshooting2 -
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming1 -
6
