Dual Monitor Setup Question
Go to solution Solved by skullbringer,
yes. dvi->vga adapter works fine
I'm running this 6870. I am currently using the HDMI connection to connect to my monitor (which I do not like, it keeps falling off  :(). I have a couple really old monitors in my house but they all use VGA. So my question is can I use a DVI to VGA adapter or something and run a secondary/dual monitor set up?
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
