Ok so here it is,
I have a 27inch monitor running off HDMI and two auxiliary ones running off DVI (one has a DVI to VGA adapter. This is all running off a R9 270 (non X). One of the DVI displays dose not display anything, this is the DVI with a VGA adapter in it. It shows up when I open screen resolution on windows but it does not let me select it becuase when i do it says: "Unable to save display settings".
Any fixes?
Thanks slyffer6
https://linustechtips.com/topic/495202-3-display-help/
Some cards don't support running a VGA adapter off of DVI, I have a friends with a 970 that does this.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/495202-3-display-help/#findComment-6626239
Ok so here it is,
Any fixes?
Thanks slyffer6
Switch around the DVI inputs, see if that works.
But I think you do need 1 active displayport used though.. not sure
Edit: yeah you said it worked before.. you need 1 active diplayport to DVI adapter
https://linustechtips.com/topic/495202-3-display-help/#findComment-6626274
Ah, ok, anyway one is DVI-D and one is DVI-I
Yeah, that is why I asked you to switch them, DVI D doesnt support being turned into VGA (while DVI I does), but since you say it worked before adding the third... that is not the problem. The problem is that AMD 200 series cards need at least 1 active displayport used if you want 3 monitors
https://linustechtips.com/topic/495202-3-display-help/#findComment-6626320
THANK YOU!!!!!!!!!!
If i oreder a displayport to VGA would that work?
https://linustechtips.com/topic/495202-3-display-help/#findComment-6626322
THANK YOU!!!!!!!!!!
Yeah.
https://linustechtips.com/topic/495202-3-display-help/#findComment-6628695
