Need Help Finding Cooler
Solved by nightlitezzz,
Prolimatech Megahalems with Akasa Vipers/Be Quiet! Silent Wings 2/Noctua F12s would be great. I couldn't find a CPU cooler height support for that case though.
Thermalright Archon SB-E X2
Thermalright Venomous X
Prolimatech Armageddon
Noctua NH-U14S/NH-U12S
Be Quiet! Dark Rock 2
If you want a dual tower you can get
Be Quiet! Dark Rock Pro 2
Phanteks PH-TC14PE
Thermalright Silver Arrow SB-E Extreme
Noctua NH-D14
Deepcool Gamer Storm Assassin
What motherboard and RAM are you using?
