Hi, I'm building a loop in the arc mini R2. I'm planning to fit 2 240mm rads, one on top which is not an issue and one in front, which is posing a bit of a problem. According to Fractal, I have 275mm of clearance for my front rad without removing ODD bays, which I don't want to do considering I'm already removing all HDD cages. Does anyone know of any rads that would fit here? I'm not too pick on thickness, but I'd prefer at least 3cm. I know they exist, I saw one on PCPartPicker,but the guy didn't respond when I asked. Thanks guys!
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/494020-arc-mini-r2-front-radiator/
Thanks for the welcome. Unfortunately, the whole idea of my post was that I need a radiatior that WON'T extend into the ODD area. I know it's a tight fit, but I've also seen builds where the rad just barely fit. If I was to remove the bays, then I'd have nowhere (well nowhere not ghetto) to mount a hard drive, and that's why I'm hoping someone knows a rad that'll fit.
