What is the best way to clean my front dust filter on my Corsair 450D case? It has a brushed aluminium finish, so is it safe to run under a tap and dry properly? I don't have any compressed air but could always buy some if needed?
CPU: Core i7 4790k | Mobo: Asus Z97-P | RAM: Corsair DDR3 XMS3 8GB | GPU: Gainward GTX 970 4GB |Storage: 1TB Seagate Barracuda | PSU: Cooler Master BII-600 | Cooling: Corsair H110i GTX | Displays: 2x Dell U2414h | Kb: Corsair K70 RGB Cherry MX Brown | Mouse: Corsair Raptor M45 | Case: Corsair 450d Console: Xbox One Ext: DXRacer F-Series Red, Trust Tytan 2.1 Sub & Speakers, HyperX Cloud II, SCUF Infinity1 X1 Controller | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/493329-cleaning-out-dust-filter/
Are you serious? Just blow the dust out with your mouth...
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/493329-cleaning-out-dust-filter/#findComment-6608922
