Is a Corsair RM 850 watt enough for a 2nd EVGA GTX 970 SC?
ImRyan
Yes. A 750W one would suffice.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Yes. The 970 in SLI can run on as little as 650W comfortably.
if you have to insist you think for yourself, i'm not going to believe you.
