new build need help with drivers
Go to solution Solved by DumbTrollface,
hmm ok,, i just checked and the fans on the gpu start up on boot but once windows have loaded in it they stop ? im confused
The 900 series cards stop their fans until the hit a certain temperatur. It works fine
Just go to the respective websites and download the drivers (btw you don't need drivers for your cpu)
EDIT : http://msi.com/product/motherboard/support/H97-GAMING-3.html#down-driver
These are the drivers for the mobo
And for the GPU just download geforce experience
