I need a gaming pc that is in the 1400$ price range. Its going to be primarily gaming. I would like to play high end games like Fallout 4 and Just Cause 3 at 1080p 60fps. I would like to stick with intel/nvidia but if amd has a better graphics card go for it. With OS and Keyboard/Mouse and i don't need a monitor right now because i will run it through my tv.  I'm ordering all parts off of newegg. Thanks in advanced
https://linustechtips.com/topic/491910-need-a-1400-build/
I need a gaming pc that is in the 1400$ price range. Its going to be primarily gaming. I would like to play high end games like Fallout 4 and Just Cause 3 at 1080p 60fps. I would like to stick with intel/nvidia but if amd has a better graphics card go for it. Thanks in advanced
Do you need a monitor, keyboard, and mouse?
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594719
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($138.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($639.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($56.10 @ SuperBiiz)
Total: $1416.09
Generated by PCPartPicker 2015-11-25 00:01 EST-0500
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594731
Total: $1416.09
IS there any possible way you could make that same list but all coming for newegg and keeping the graphics card but staying in the 1400$ range
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594792
Am not sure how well a TV would do, unless it has 60 Hz refresh rate.....
Here:
http://pcpartpicker.com/p/9yc3P6
Systems built (personal) | 1. Bad Wolf (Has passed on to PC Heaven): https://ca.pcpartpicker.com/b/zX9WGX |  2. Red Husky: https://ca.pcpartpicker.com/b/Mwhypg
Systems built (for commission) | 1. Red Fox: http://ca.pcpartpicker.com/b/W4LD4D | 2. Not Namedhttp://ca.pcpartpicker.com/b/TMhqqs 3. Bad Wolf 2.0: https://ca.pcpartpicker.com/b/7p8Ycf upgraded Bad Wolf to an I3-7100 for my friend as a gift|
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594832
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($104.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($689.99 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($79.98 @ Newegg)
Total: $1456.81
Generated by PCPartPicker 2015-11-25 00:21 EST-0500
Newegg and Amazon:
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($139.99 @ Amazon)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Total: $1410.81
Generated by PCPartPicker 2015-11-25 00:22 EST-0500
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594837
Just curious why 16gb of ram
16 is nice, not needed, but nice, and new games are asking a little more (battlefront recommends 16 and while it doesn't use 16, it can use more than 8)
CPU: i5-4690K @ 4.0GHz GPU: Gigabyte Gtx 970 WindForce MOBO: Gigabyte Z97 Gaming-3 CASE: Corsair Carbide 200R PSU: Corsair RM750
RAM: Corsair Vengeance 4GBx4  MOUSE: CM Mizar KEYBOARD: Logitec G110
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594844
Total: $1456.81
Newegg and Amazon:
Total: $1410.81
This is absolutely amazing but it doesn't have an operating system but thank you so much
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594891
You can easily get it off G2A or /r/microsoftsoftsoftwareswap for $25 at the most.
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6594898
That is a valid point
Although on most budgets, better to squeeze in a better gpu instead of the extra ram xD
https://linustechtips.com/topic/491910-need-a-1400-build/#findComment-6595423
