Hi all,
After looking at some prebuilt "gaming" PCs online, I've decided to come to my senses and build my own rig. Specifically, I have my eye on Linus' "Ultimate Value Gaming Build," http://linustechtips.com/main/topic/281756-ultimate-value-overclocked-build-guide/
What I'm wondering is, do you all have any advice, recommended changes to the build (possibly quad core?), or anything else you feel I should know for my first real build? I'll take whatever I can get at this point. I'm dealing with a pretty low budget so nothing too crazy :P
Thanks in advance!
EDIT: My goal is to run Sims 3 (because Sims 4 is disappointing at best) on full settings @ 1080p with no lag or stuttering. Don't judge me... I already know I need a life :P
Have you tried turning it off and on again?
https://linustechtips.com/topic/491362-build-advice/
Hi all,
Thanks in advance!
What games are you wanting to play?
What's your overall budget?
Assuming USD because you're in Miami?
While the G3258 does well in a lot of games, a quad core makes a lot of sense (like you were suggesting) because a lot of newer games simply don't run well (if at all without hacking them) on dual threaded CPUs.
Sig under construction.
https://linustechtips.com/topic/491362-build-advice/#findComment-6587607
The most demanding title at the moment is The Sims 3, a lot of my other games are older ones I grew up playing that I just can't let go of :P I only get paid every two weeks so I will be buying parts incrementally but Ideally less than $1,000 USD.
https://linustechtips.com/topic/491362-build-advice/#findComment-6587624
Okay, I'm gonna see what I can get for $900 ish.
https://linustechtips.com/topic/491362-build-advice/#findComment-6587631
This is probably going to be slightly overbudget when Black Friday/Cyber Monday-esque sales are over, but:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($189.99 @ Micro Center)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($109.99 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card  ($294.98 @ SuperBiiz)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  ($39.99 @ Newegg)
Total: $869.91
Generated by PCPartPicker 2015-11-24 08:17 EST-0500
https://linustechtips.com/topic/491362-build-advice/#findComment-6587640
Awesome, thanks a million! Like I said I really do like that ultimate value build, so I was hoping to base it around that. But any other suggestions are greatly appreciated and I will definitely consider them!
https://linustechtips.com/topic/491362-build-advice/#findComment-6587641
Total: $869.91
Hmmm... I like it! The GPU might be a little overkill for me but I'd much rather have too much than not enough.
https://linustechtips.com/topic/491362-build-advice/#findComment-6587649
With the Ultimate Value Build I'm pretty sure you can get a lot better in terms of performance for your budget, which is why I went with what I did for that quick and dirty example.
https://linustechtips.com/topic/491362-build-advice/#findComment-6587653
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($56.10 @ SuperBiiz)
Total: $931.67
Generated by PCPartPicker 2015-11-24 08:23 EST-05000500
https://linustechtips.com/topic/491362-build-advice/#findComment-6587662
PC Build Guide – Budget Kaveri: (480$)
*CPU: AMD Athlon X4 860K (OCing needs a better cooler!)
*Mobo: MSI A88X-G45 Gaming FM2+
*RAM: Patriot Viper 3 (4x4) DDR3-2133MHz / Patriot Viper 3 (4x4) DDR3-2400MHz (OC)
*GPU: MSI Radeon R9 370 2GB (860K should not have a GPU better than R9 285 or GTX 960!)
*PSU: EVGA SuperNOVA G2 550W
*480$ Budget: http://pcpartpicker.com/p/7KmWkL
PC Build Guide – Budget Vishera: (575/577$-612$)
*CPU Option 1: AMD FX-6300 + Cooler Master 212 Evo (212 Evo will not cool of the VRMs)
*CPU Option 2: AMD FX-6350 (OCing needs a better cooler also it is very loud!)
*Mobo: MSI 970 Gaming AM3+ (990FX version only have more features and a better heat sink on the board)
*GPU: MSI Radeon R9 380 2GB / MSI Radeon R9 380X 4GB
*575/577$ Budget: http://pcpartpicker.com/p/HYjLGX
*612$ Budget: http://pcpartpicker.com/p/dkH699
PC Build Guide – Budget Haswell: (574$-x749$)
*CPU: Intel Core i5-4460
*Mobo: MSI H97 PC Mate LGA1150
*RAM: Patriot Viper 3 (4x4) DDR3-1600MHz
*GPU: MSI GeForce GTX 950 Gaming 2GB / MSI GeForce GTX 970 Gaming 4GB
*574$ Budget: http://pcpartpicker.com/p/PzFhf7
*749$ Budget: http://pcpartpicker.com/p/vMT7Vn
PC Build Guide – Budget Skylake: (590$-770$)
*CPU: Intel Core i3-6100 / Intel Core i3-6300
*Mobo: MSI H170A PC Mate LGA1151 / MSI H170 Gaming M3 LGA1151
*RAM: Patriot Extreme Performance (4x4) DDR4-2133MHz / Patriot Viper 4 (4x4) DDR4-2666MHz (2666MHz needs the Gaming board)
*590$ Budget: http://pcpartpicker.com/p/xDssTW
*770$ Budget: http://pcpartpicker.com/p/XPq7Vn
Why RAM matters!
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/491362-build-advice/#findComment-6588994
You can probably get the Q6600 and the motherboard cheaper used and I think you can probably find a better cooler that will allow you to push for higher overclocks without breaking the bank or too much effort. The 8400 GS is ancient though and I wouldn't recommend using it for anything more than retro games at this point, though it might get you through some older games or older indie games on low settings. With the case, I can't comment on it but that power supply, I've been running it in my main rig for a while and in a different rig that's much less demanding for a while longer. I'm not sure it's the best but it hasn't done anything bad for me yet which i guess is a good sign.
I would go for a slightly higher end DVD drive, that one might be obnoxiously loud, and I think you should get your Windows key from /r/microsoftsoftwareswap because it's probably going to be much much cheaper.
For the RAM I don't think you'll be able to run at near the rated speed for those DIMMS and I don't think that you're going to benefit with having that much on an older system.
I definitely don't think you should be spending that much on those components.
https://linustechtips.com/topic/491362-build-advice/#findComment-6589498
