Cooling for new Build
I am building a new PC and I dont know if I will be needing a different CPU cooler or the stock cooler will be fine.
I will be using the PC for about 16 hours per day.. And the temperature in our country is about 34°C.
Here are the specs:
Processor: Intel i5-4460
Mobo: Asus B85M-Gamer
GPU: Sapphire R9 380 4GB OC
RAM: Gskill RipjawsX 2x4GB DDR3 1600
HDD: 500GB WD Blue
PSU: SeaSonic S12II 620W 80+ Bronze
Casing: Deep Cool Tesseract SW
I really have a limited budget so I am hoping to get just what I need.. Im not expecting it to heat too much since I dont OC.
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/491302-cooling-for-new-build/
Here are the specs:
HDD: 500GB WD Blue
You don't actually need a new cooler unless your stock cooler is broken or somewhat like that. If you're going to buy a CPU cooler go for an Coolermaster Hyper 212 EVO, Cryorig H5/H7 or Scythe Mugen 4.
https://linustechtips.com/topic/491302-cooling-for-new-build/#findComment-6586889
