Try removing usb dongle and check and check fo rmotherboard stand  offs and then check connections (like fit them perfectly)
THE LITTLE DEVIL : i5 4690k on NOCTUA NHD15
Asus z97 sabertooth mark 2
WD black 1TB & WD Green 2TB HDD, Samsung 840 Evo 240gb & Hyperx 240gb SSD
RAM- Corsair vengence 16gb and hyperx fury 8gb
PSU-Seasonic sII 620 wtt power supply
PErPHERaLS: Logitech g403 mouse, Redgear cherry MX brown switches, Logitech gamepad f310,Cosmic byte XXL RGB mousepad
Audio: SennheiserHD 558 and antlion mod mic
PHOnE: Realme 3 pro
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6585615
Armaggeddon 500W
Like CovertCamper said, sketchy... never heard of that brand
Can you try another PSU? Borrow a friends maybe?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6586121
Test with a graphics card installed, if it works then.. then you know your problem is with your motherboard onboard graphics.
My Rig: - Gigabyte Z97 X5 MB / Core i7 4790K @ 4.4Ghz - Water Cooled Coolmaster AIO Loop (Push - Pull Config)/ 8GB Corsair Dominator ram at 2400Mhz / Palit Jetsteam GTX 980 OC edition / 128GB SSD OS / Program Drive + 2 TB hard drive storage / Win 10
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6587590
 Work perfectly fine even with the dongle.
Wait wait....
Are you saying it works fine outside the case but doesn't inside the case??
If you are then your motherboard is shorting out on the case...
The good news is it can be resolved with something as simple as putting standoffs correctly to lift the board from the case.
The bad news is, if you are shorting the board out then there is a very good chance you have messed the baord up completely.
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6587699
@o0odellero0o That's exactly what I figured.   Damn I'm good. ;)  Check the motherboard standoffs to ensure they're in the right mounting holes for your motherboard and and don't have any crossed threads. Crossed threads would cause them to stand unevenly. To check that, you might need to remove and replace them because it might be hard to see. The case probably came with a little tool for that. If not, just use some needle-nose pliers.
Also make sure you didn't over-tighten the motherboard screws or cross any of those threads.
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6588021
Great minds think alike!
Experience is great teacher!
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6588246
Try screwing every screw in mobo tray and try to run it
check your motherboard standoffs too or replace them with otherones that came with the case
PHOnE: Realme 3 pro
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6595004
Wait wait....
Case using thermaltake h24 no need standoff.
https://linustechtips.com/topic/491183-help-i-have-no-idea/#findComment-6603577
