Are there any good colored water coolers?
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/490491-colored-water-cooler/
Rajintek Triton
The newegg reviews aren't that on it good :/
https://linustechtips.com/topic/490491-colored-water-cooler/#findComment-6577593
What exactly do you mean by coloured water coolers? Do you mean ones with different colours of coolant? or something like the corsair h105 where you can change the colour of part of the waterblock?
If you're looking for something like the raijintek triton, I'm fairly sure that's the only AIO you're gonna find that's like that.
https://linustechtips.com/topic/490491-colored-water-cooler/#findComment-6577624
 coloured waterblock
https://linustechtips.com/topic/490491-colored-water-cooler/#findComment-6577669
its pretty decent
LTT's one cracked and leaked
https://linustechtips.com/topic/490491-colored-water-cooler/#findComment-6577723
not really anything that is that displayable. they either leak like a sieve, weak
and noisy, or completely stop working (by the reviews). otherwise the water
blocks from ek supremacy are about the most transparent and thats using a
$400-$700 custom kit.
https://linustechtips.com/topic/490491-colored-water-cooler/#findComment-6577745
