Bukkit / Java plugin help
I am wondering if anyone here would like a plugin made for their Minecraft server I am learning the Bukkit API and java at the same time and I would like a challenge, so if anyone needs some kind of plugin made I would be happy to try and help.
I have started to work with mySQL in Java so that's a thing.
So yeah...
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/
So yeah...
you know bukkit is dead right ?
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576524
You know Spigot is taking over right? They still use a lot of the bukkit api its pretty much that.
http://www.spigotmc.org/
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576536
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576542
Not quite, there are plenty of modified versions of it still running, so the API is still used pretty much universally.
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576552
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576555
true. but bukkit is dead
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576579
spigot
but official bukkit is dead
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576581
spigot
Yes, bukkit itself is dead, but the API is not.
https://linustechtips.com/topic/490398-bukkit-java-plugin-help/#findComment-6576833
