CPU cooling
Go to solution Solved by Godlygamer23,
It will allow the CPU to run cooler, which can certainly extend its life. However, another benefit to having an aftermarket cooler can simply be....it's quieter versus using the stock cooler.
Hi guys, so i have a Intel i3-3220 in this computer, it work like a year with the default cooler.
My cuestion is if i buy a new cooler it will extend the life of que cpu or just refrigerate?
I want to buy this one:
Sorry if i have bad inglish, im from Uruguay :P
Follow your post! Also welcome to the forums :)
https://linustechtips.com/topic/489725-cpu-cooling/#findComment-6569526
https://linustechtips.com/topic/489725-cpu-cooling/#findComment-6569530
If your temps are constantly over 80ºc, then yeah, the cooler will extend the life of your CPU. But if not, it won't really change much, aside for reducing noise.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/489725-cpu-cooling/#findComment-6569537
Tnks you bro, I do not regret to coming to this forum
Happy to help.
https://linustechtips.com/topic/489725-cpu-cooling/#findComment-6569568
