Hay guys i plugged me xbox into my new monitor and it worked fine,but the only problem is is doesn't have speakers. so i can play games fine, but i can hear anything. this is the monitor http://www.amazon.com/Acer-XB270H-Abprz-27-inch-Widescreen/dp/B00NUCRBCU i have sibera v2s and i was wondering if there is a way to put the sound through the headset. i also have external speakers. the mic has an audio input and mic output cords, and the speakers have just an audio input. thanks for the help guys.
https://linustechtips.com/topic/489016-xbox-audio-help/
If your Xbox controller has a 3.5 mm headphone jack you can plug your Siberia into your controller and get audio that way, otherwise you either have to buy a stereo headset adapter or an Astro Mixamp/Turtle Beach DSS to plug your headset into (+ it will add virtual surround sound to your headphones).
DSS
Mixamp
plug your PC back into your monitor... problem fixed...
If you're not helpful don't bother to respond at all.
144Hz goodness
https://linustechtips.com/topic/489016-xbox-audio-help/#findComment-6563807
