So I'm folding and my temps are at 72°C atm with 100% usage. I'd love to limit this temp (to like 60-65) so my usage isn't 100% anymore and my stream doesn't lag anymore.
How do I do this? :)
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/488766-set-a-max-temp-for-gpu/
Solution, don't fold while streaming
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/488766-set-a-max-temp-for-gpu/#findComment-6559450
I'm watching a stream :)
https://linustechtips.com/topic/488766-set-a-max-temp-for-gpu/#findComment-6559471
Can't you turn down the folding power?
Main Rig
Plex Server WIP
https://linustechtips.com/topic/488766-set-a-max-temp-for-gpu/#findComment-6559479
You can but I think that when the slider is set at "medium" it only folds when on idle.
I haven't tried it so I'll try it, thanks :)
https://linustechtips.com/topic/488766-set-a-max-temp-for-gpu/#findComment-6559488
