Hi. I need help. Is this a solid build. Or should I re-Think it.
http://pcpartpicker.com/p/zmzTK8
$900 is your budget?
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558622
Lol hit the BB Code button and paste it. scrub
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558625
It's $800
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558628
It's $800
$830... but Yeah. :D
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558631
This will perform better
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.88 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($70.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($274.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($34.99 @ Micro Center)
Total: $742.71
Generated by PCPartPicker 2015-11-20 13:58 EST-0500
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558633
Solid build, good parts.
For gaming though, you may find a locked Haswell I5 (4460) and a R9 390 to be a better combination.
Or, if you're willing to put an extra $100 in, you can get a R9 390 with that CPU.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558643
Nope it's $800
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558650
For productivity is good,
For gaming you don't really need skylake, you could get a haswell cpu and send the extra money you saved torwards a graphics card or something else
https://linustechtips.com/topic/488690-check-out-my-build/#findComment-6558686
