So ive been a long time hardware enthusiast, and im starting to worry ive made some bad choices along the way, heres my current system spec:
Case: NZXT H440
PSU: Corsair rm850
Cooler: Corsair h110
Fans: 2xCorsair SP140 White LED + 4x Corsair SP120 (white band)
MOBO: Asus Z97-AR
CPU: 4790k@stock
RAM: Avexir core white 8gb(2x4) @ 2133MHz RAM Speed, CAS 11-11-11-31 Timings, 1.60-1.65v
GPU: EVGA GTX980 4gb SC ACX
Storage: 1tb seagate hdd (no clue on spec)
                500gb back up drive (again no clue on other spec as i 'inherited it')
                120gb kingston hyper X ssd (firstgen)
Peripherals are a WIP but currently use the razer deathstalker ultimate (want a k95 so bad) -  a razer naga epic (switching for a g600 soon) some 27" samsung LED tv/monitor thing connected by HDMI.
ill edit the post with screenshots regarding temps when im home but generally around 35c idle and 65c load on cpu and my gpu is about 40c idle and 67c load.
Im curious to know if anyone can help me out with suggestions to improve this set up, im part tempted to upgrade to 2011-v3 as i now use my pc to play around with VM'S , but i no real rush.
I just want my current set up to be as powerful as it can be.
tyy <3
| Laptop: Asus UA310a ElementaryOS/Ubuntu 18.04 | Desktop: Intel i7 6700k - Asus Maximus Impact VIII - Cryorig C7 - 16gb Avexir DDR4 - NVIDIA GTX 980 - Kolink Rocket |
https://linustechtips.com/topic/487959-optimisation-help/
That's a pretty powerful setup already. if you wanna upgrade you can upgrade to 6700 with DDR4. Or go all out and go 6950x.
GPU-wise: Can always upgrade to 980ti (maybe SLI)
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/487959-optimisation-help/#findComment-6549143
