Need Case suggestions (second-guessing Enthoo Luxe)
Hello fellow techtippers,
I have been planning for a rebuild of my current rig, and while considering a completely custom case, I have decided to go with a pre-made case for this build.
I need your suggestions for what case to go with.
Criteria:
Eye catching (at least unique)
3+ 5.25 bays
Full ATX
Large window to compliment the LEDs of the HUE+
Must be able to fit the H100i GTX in the top, and the EVGA Hybrid 980ti's rad preferably in the front.
And
Cannot be the H340.
TheRedDragon    |i7-5820k (4.2Ghz) || MSI X99S SLI Plus || Crucial 2x8gb 2133hmz DDR4 || MSI GeForce GTX 980Ti 6Gb || Sandisk 128Gb SSD || Seagate Barracuda 3Tb |EVGA 1000W 80+ Pltnm ||
dossium.net >
Posts that won the internet - Verticle Mice
You're actually be using three 5.25" drives?
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
A double bay reservoir and a fan controller?
Ya in win's are sexy, I like the open frame the most :)
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
Optical DVD/CD/BluRay RW for my live discs and video burning.
Hue+  5.25 controller
SDHC/SD/lotsofothersdtypes 5.25 reader
Method to my madness.
dossium.net >
Looked at it already, can it even be bought?
dossium.net >
