I've been having this Issue for a while now, Minecraft keeps crashing and I don't know why. If you could help, that could be appreciated.
---- Minecraft Crash Report ----
// On the bright side, I bought you a teddy bear!
Time: 11/15/15 7:04 PM
Description: Ticking memory connection
java.lang.NullPointerException: Ticking memory connection
at com.flansmod.common.driveables.DriveableType.getDriveable(DriveableType.java:544)
at com.flansmod.common.driveables.DriveableData.readFromNBT(DriveableData.java:45)
at com.flansmod.common.driveables.DriveableData.<init>(DriveableData.java:34)
at com.flansmod.common.driveables.ItemVehicle.getData(ItemVehicle.java:159)
at com.flansmod.common.driveables.ItemVehicle.func_77659_a(ItemVehicle.java:136)
at net.minecraft.item.ItemStack.func_77957_a(ItemStack.java:146)
at net.minecraft.server.management.ItemInWorldManager.func_73085_a(ItemInWorldManager.java:316)
at net.minecraft.network.NetHandlerPlayServer.func_147346_a(NetHandlerPlayServer.java:539)
at net.minecraft.network.play.client.C08PacketPlayerBlockPlacement.func_148833_a(SourceFile:60)
at net.minecraft.network.play.client.C08PacketPlayerBlockPlacement.func_148833_a(SourceFile:9)
at net.minecraft.network.NetworkManager.func_74428_b(NetworkManager.java:212)
at net.minecraft.network.NetworkSystem.func_151269_c(NetworkSystem.java:165)
at net.minecraft.server.MinecraftServer.func_71190_q(MinecraftServer.java:659)
at net.minecraft.server.MinecraftServer.func_71217_p(MinecraftServer.java:547)
at net.minecraft.server.integrated.IntegratedServer.func_71217_p(IntegratedServer.java:186)
at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:427)
at net.minecraft.server.MinecraftServer$2.run(MinecraftServer.java:685)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Ticking connection --
Details:
Connection: net.minecraft.network.NetworkManager@404c5765
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.7.10
Operating System: Windows 8.1 (amd64) version 6.3
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 560506376 bytes (534 MB) / 1440288768 bytes (1373 MB) up to 2120679424 bytes (2022 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx2G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn256M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
IntCache: cache: 0, tcache: 0, allocated: 13, tallocated: 95
FML: MCP v9.05 FML v7.10.99.99 Minecraft Forge 10.13.4.1517 Optifine OptiFine_1.7.10_HD_U_C1 16 mods loaded, 16 mods active
States: 'U' = Unloaded 'L' = Loaded 'C' = Constructed 'H' = Pre-initialized 'I' = Initialized 'J' = Post-initialized 'A' = Available 'D' = Disabled 'E' = Errored
UCHIJAAAA mcp{9.05} [Minecraft Coder Pack] (minecraft.jar)
UCHIJAAAA FML{7.10.99.99} [Forge Mod Loader] (forge-1.7.10-10.13.4.1517-1.7.10.jar)
UCHIJAAAA Forge{10.13.4.1517} [Minecraft Forge] (forge-1.7.10-10.13.4.1517-1.7.10.jar)
UCHIJAAAA TooManyItems{1.7.10} [TooManyItems] (minecraft.jar)
UCHIJAAAA OpenModsCore{0.8} [OpenModsCore] (minecraft.jar)
UCHIJAAAA advancedgenetics{1.5.9} [Advanced Genetics] (advancedgenetics-1.7.10-1.5.9.jar)
UCHIJAAAA Backpack{2.0.1} [backpack] (backpack-2.0.1-1.7.x.jar)
UCHIJAAAA BiblioCraft{1.11.0} [biblioCraft] (BiblioCraft[v1.11.0][MC1.7.10].jar)
UCHIJAAAA CarpentersBlocks{3.3.7} [Carpenter's Blocks] (Carpenter's Blocks v3.3.7 - MC 1.7.10.jar)
UCHIJAAAA chisel{2.5.0.43} [Chisel 2] (Chisel2-2.5.0.43.jar)
UCHIJAAAA customnpcs{1.7.10d} [CustomNpcs] (CustomNPCs_1.7.10d.jar)
UCHIJAAAA flansmod{4.10.0} [Flan's Mod] (Flans Mod-1.7.10-4.10.0.jar)
UCHIJAAAA journeymap{@JMVERSION@} [JourneyMap] (journeymap-1.7.10-5.1.0-unlimited.jar)
UCHIJAAAA mcheli{0.10.7} [MC Helicopter] (mcheli)
UCHIJAAAA OpenMods{0.8} [OpenMods] (OpenModsLib-1.7.10-0.8 (1).jar)
UCHIJAAAA OpenBlocks{1.4.4} [OpenBlocks] (OpenBlocks-1.7.10-1.4.4.jar)
OpenModsLib class transformers: [stencil_patches:FINISHED],[movement_callback:FINISHED],[map_gen_fix:FINISHED],[gl_capabilities_hook:FINISHED],[player_render_hook:FINISHED]
Class transformer null safety: all safe
Stencil buffer state: Function set: GL30, pool: internal, bits: 8
Profiler Position: N/A (disabled)
Vec3 Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Player Count: 1 / 8; [EntityPlayerMP['darkguy780'/5, l='beachtown', x=191.79, y=72.00, z=444.51]]
Type: Integrated Server (map_client.txt)
Is Modded: Definitely; Client brand changed to 'fml,forge'
Btw, sorry for the spam with the crash report.
https://linustechtips.com/topic/485720-minecraft-crash-please-help/
You might need more dedotated WAM...
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
