Radeon Pro won't open?!
h3ll0
For a long time I've been trying to use RadeonPro, but every time I install it the program opens in the system tray then disappears. I've tried running it in every compatibility mode,running as administrator, and installing different graphics card drivers, but it still won't open and it is frustrating.
I have a Sapphire HD 7870 running Catalyst 13.8 Beta.
Any help is appreciated  :D
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
try the 32 bit version 64 is buggy .
also try delete the program an folder its in and reinstal it .
folder normallyis C:\Program Files (x86)\RadeonPro or something like that .
hope it works
