So im buying my parts real soon and Im not sure if I need another pump the total length of the tubing will be around 5 metres including the blocks etc.
So in the diagram the loop starts at the left reservoir(red) goes into the next reservoir goes into the pump (https://shop.ekwb.com/ek-xtop-ddc-3-2-pwm-elite-acetal-incl-pump)(yellow) goes into the rad(blue) next gpu block (blank) another rad (blue) cpu block (blank and the rad (blue) goes back again into the left reservoir and starts again. Do I need another pump and where should I put it keep in mind the loop is horizontal so its hard making the pump be under the reservoirs. Also when I fill it should I just raise the reservoirs somehow?
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/484179-pump-power-questions-and-loop-order/
loop order dosent matter as long as Your reservoir sits above Your pump and they are conected, after that it dosent matter at all.
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
i know that but do I need another pump
i would run dual pumps on that loop, since you have many Blocks its going to be pretty restrictive. (use this for Your pumps: https://shop.ekwb.com/ek-xtop-revo-dual-d5-pwm-serial-incl-pump )
My pc:
(Black Glacier)
My server:
As recommended a series or even single D5 can handle the loop they are fairly powerful pumps, for fill or the setup you could create angled mounts or tilt the reservoir so it directs the fluid down to the pumps if desired but having them mounted horizontal isn't a problem also.
1 pump should be able to handle that.  You don't need crazy high flow rates for watercooling to work at full effect.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
