Hey my WD blue hard drive pins were bent . I need this data!!
RIP
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/484162-broken-hdd-pins-help/#findComment-6494489
IDE?
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/484162-broken-hdd-pins-help/#findComment-6494496
Pic
Where? :P
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/484162-broken-hdd-pins-help/#findComment-6494507
Pic
Pic never got posted.
By the sounds of it you'll need to take it to a data recovery agency if its what it sounds like.  Do not attempt to open the drive at all, if you do all your Data is gone forever.
Also, learn from this and take backups in the future.
https://linustechtips.com/topic/484162-broken-hdd-pins-help/#findComment-6494537
@mindfucnugget
The only HDD pins would have to be an IDE drive and those pins are fairly strong so use a bird beak pliers to bend it kind of straight, don't pull on them, and use the IDE connector to do the rest, it will work, well should.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/484162-broken-hdd-pins-help/#findComment-6494604
