I was wondering if i don't have a 6-pin on my PSU can i use an adapter? Is it good?
Well usually yes as long as your PSU can handle it, they are a bit frowned upon since those molex connectors have a history of melting if too many amps are pulled through it with a bad connection.
https://linustechtips.com/topic/483284-molex-to-6pin/#findComment-6483065
