Pretext:
I advised my friend building a low-end gaming PC 2 years ago. It consisted of a low-power AMD APU, GTX 660, generic mobo, hdd, cd drive that fit the bill, and a Corsair 600W 80+ Bronze PSU.
This build was strictly for gaming purposes (originally) and was decent, pulling around 45fps on high on most games at the time of purchase.
Recently my friend started streaming to Twitch from the same PC from which he is playing, resulting in extremely bad gaming performance due to the rubbish old CPU.
He complains to me and I think also secretly blames me for the bad performance, so I told him the best thing for him to do would be to upgrade CPU and PSU, and since he has AMD he had to upgrade his mobo too.
He ended up looking on loads of different forums, all advising him to buy an i7 4790k, because its "great for streamers and youtubers" and a like motherboard to put it in.
So he did it without consent from me (although it is his money so I don't really want to debate it with him) and then complains to me that he still isn't getting good performance. He says he recently brought COD: Blops III and it runs "like shit, it's unplayable" (which I'll presume is less than 30fps). I don't have anymore info.
I tried to explain it to him but he really doesn't get it, and is now taking advice from someone oversees (USA) who has told him to "Just buy a new graphics card and it'll be fine" which is the total opposite.
tl;dr: friend got a low-end PC, and put some high-end parts in it expecting to make it 1000% better, didn't work due **something**
The Big Question(s)
Am I right to assume it is the 600 Watt Corsair Power supply that is causing the CPU and GPU to bottleneck, thus producing worse performance?
Is there any software which I could use which would tell me things like how much power the CPU, GPU, Mobo, etc. Is getting? along with either an in-game overlay, and/or a log file (or graph) showing the performance over time so I can play a game that lags to see what is causing it.
Thanks to whoever reads and responds, sorry its so long. Also, I'm writing a 1600 page novel if anyone would like to read it, it'll be out on amazon in 15 minutes.
If you found my post helpful make sure to press the "Like This" Button  ;)
https://linustechtips.com/topic/483104-system-bottlenecking-issue-help-appreciated/
That PSU will never bottleneck anything.
The problem is the GPU, it's old and bad by today's standards. I think the best game it would play is BF4, which is two years old.
I'd tell him to save up a bit and get a 390/X (390X preferred,) and a new PSU. Or, save up even more and get a 980ti.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
If the PSU weren't strong enough the pc wouldn't even power on. It is probably his GPU that isn't very strong.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
Video card is the bottleneck, not the PSU. If the PC wasn't getting enough power it would shut down.
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
http://linustechtips.com/main/topic/352924-gta-v-pc-tweak-guide/#entry4810752
If you are technically adapt as you seem you are, you will know what to do with this short guide for you to find what the bottleneck is.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
This statement is untrue and misleading.
Maybe I wasn't being specific enough. I'm not saying it isn't enough to turn on whatsoever, just when the system demands more than 80% PSU utilization, it is asking for more than the power supply can... supply.
Thanks! This is more than I need to diagnose this issue.
As with Zyntaxable's post, this is untrue.
If it's asking for more than it can receive, it will also shut down :P Or burn your PC along with it more likely.
Do note if you want to see CPU temps, you'll need to pair it with HWInfo.
I didn't say you wouldn't be able to turn on your PC. zyntaxable said that. If the PC needed more power than the PSU can supply the PSU would shut down itself and the whole system.
Do note if you want to see CPU clock speeds, you'll need to pair it with HWInfo.
What do you mean "burn your PC along with it"?
If it's a crappy PSU, and you force it to go over what it can provide, it will either catch fire, or shock everything in the PC.
Like we all said that a PSU can't bottleneck fps because if you overload it, if it's decent the PC will just shut down due to safety measure put in place or it could just burn or fry itself.
Either way the GPU is the clear problem and BO3 PC is a glitchy game anyways so I way try a different stable game to determine performance
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
Its not just BO3. He says he gets poor performance in most game, he says, so I will have to go and check what the problem is ASAP.
