Additional air cooling needed?
The case comes with two fans, one in front, the other in back. But I need this assesed to see if I will need more Aircooling
I do alot of audio production.
Everything helps!
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($379.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($91.98 @ OutletPC)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard  ($238.99 @ SuperBiiz)
Storage: Samsung 850 Pro Series 128GB 2.5" Solid State Drive  ($88.89 @ OutletPC)
Storage: Samsung 850 Pro Series 1TB 2.5" Solid State Drive  ($435.98 @ Directron)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($654.99 @ Newegg)
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer  ($53.99 @ Directron)
Operating System: Microsoft Windows 10 Pro OEM (64-bit)  ($129.89 @ OutletPC)
Total: $2791.21
Generated by PCPartPicker 2015-11-10 11:03 EST-0500
https://linustechtips.com/topic/482421-additional-air-cooling-needed/
It's always encouraged to have more intake fans than exhaust fans. So maybe get a second 120mm for the front and you'll be good!
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
The stock cooling should be adequate but you can always add or change out fans if you find it unsatisfactory.
