In the middle of purchasing my new case, settled for a Pro or Luxe, depends on how expensive the Luxe is here, otherwise ill just settle for the Pro, but i also noticed that there is a Pro M version that i have never really seen before, is it just a smaller and cheaper version of the Pro?
I kinda like the very open interior of the Pro M, nothing in the way of airflow, which is what im mainly looking for to get some air to my R9 390.
Ryzen 7 3700x, MSI B450 Tomahawk MAX, 16GB Ballistix Elite 3600MHz, MSI RTX 2070 Super Gaming X Trio, Corsair RM750x V2
https://linustechtips.com/topic/482141-phanteks-enthoo-pro-vs-pro-m/
The Pro M is just the Pro but a Mid-Tower, not a Full Tower. Same great airflow and modularity.
It's cheaper cause it's smaller, makes sense.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
I like the look of the M, but the Pro is a better value.  You get more fans, and fan hub controller and it is a full tower(not always a good thing).
True, guess i gotta find out if maybe i want something a bit smaller :)
Im gonna replace the fans anyway, so thats not really a big concern, if its the same nice build quality as the Pro and Luxe, i might consider something a bit smaller like the M.
Pro M is just the mATX version.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
I think the Pro M is still ATX, but mid tower, comes with the Enthoo Evolv ATX style interior, slide out radiator slots on top, more radiator support on front, better airflow (new modular HDD bays), I would go for the the Pro M, looks like a very nice interior, but the Pro is still a great choice as well.
I like good humans and good food
It's really good build quality, but it has no fan hub. It's mid tower, but the cable management is great.
The Laptop:
If you are going to spend more on airflow regardless, I personally like the M design(aesthetics) a lot.  The build quality is the same as the Pro, cable management is the same as well.
The Pro M is ATX.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
Yeah im kinda thinking about going for that instead now, i run a single gpu setup anyway, so no real need for a big tower. I like the fact that there is nothing blocking the airflow to the GPU, looks like there is a nice straight airflow from the front to the back right over the GPU.
Very much considering it right now instead, my current case has a fan hub, but i dont even use it anyway :)
The Pro M is ATX.
It is? Derpie derp.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
It is? Derpie derp.
Yep. 7 PCI-E slots vs 8. :)
I've got the Enthoo Pro M.  The cable management in the back is amazing.  Three dust filters.  Sliding fan tray.  Zero air obstructions.  Temps have always been 20c-44c (while gaming).
ONE COMPLAINT.  Pain in the ass reset button is under the headphone port, I accidetally reset my system 5 times before I figured the trick out. :P Plus plugging in your headphones in the front aux is a workout, it's a super super tight fit.   I'm sure if I stood up and walked away with my headphones, the towers coming with me.
i7 6700k // H110i GTX, 4xNoctua 140mm Industrial 3k // Asus Z170 Pro Gaming // 8GB 2400mhz // MSI GTX 970 // Enthoo Pro M
The IO is in a bit of a awkward position as i have my pc on the floor to the left of me, but should be fine, i use a amp/dac anyway, so the headphones port is not gonna be used :)
Almost got the MasterCase Pro 5, but the price is just ridiculous, i dont know who came up with that, but he must have been drunk. Which is kinda sad, since i really love the layout of that case, but i just cant get myself to pay that much for a midtower.
-snip-
Ah yeah, I've got mine to the right.  I think we've made a good decision going with Phanteks after all.
6f52b38709afcd9a8cd24523326dbb43.1600.jp
cda789b7c733c1227544b3f287ff928a.1600.jp
Something about this Thermaltake case though...  I love it.   $149.99 w/free shipping
