My memory is getting eaten up again and isn't clearing. It is apparently getting eaten up by MsMpEng.exe. It doesn't clear after I turn off the computer and turn it back on! Please help!post-267150-0-00881400-1447104211.jpg
| CPU: Intel i7-6700K 4.0GHz | Mobo: ASUS MAXIMUS VIII Extreme | RAM: G Skills Ripjaw V DDR4 32GB (4x8GB) 2400MHz | GPU: ASUS GTX 1070 STRIX | | Storage: Samsung 250GB SSD & WD Caviar Black 3TB | PSU: EVGA 850W | Cooling: Noctua NH-D14 | Case: Cooler Master Storm Styker |
Display: Benq XL 2430T & Dell U2414h | Keyboard: Logitech G910 Orion Spark | Mouse: Logitech G502 Proteus Spectrum | Sound: Logitech z533 2.1 Stereo Speakers |
| OS: Windows 10 |
https://linustechtips.com/topic/482023-help-memory-issue-returned/
I have 16GB of DDR4 2400MHz RAM. I know Steam is on in the background, but it should not be using 10GB of the 16GB worth. And all of those added up should not be using that much RAM.
| OS: Windows 10 |
MsMpEng.exe is a core process of Windows Defender, which is Microsoft's antispyware utility. It scans downloaded files for spyware; if any suspicious items are found, it can quarantine or remove them. It also takes steps to actively prevent spyware infections by searching the system for known worms and trojan programs.
Turn Windows defender off if you are using another antivirus.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
That's a process from windows defender; disable windows defender.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
I am not using another antivirus. But what if I turn off Windows Defender and then turn it back on? Is there any chance that it will clear my RAM usage or at least lower it?
| OS: Windows 10 |
It could. Open up Windows Defender and make sure everything looks good(updates, etc.)
I disabled Windows Defender, however, it didn't go down and my memory used didn't clear at all.
| OS: Windows 10 |
Everything is up to date. So MsMpEng.exe is used by Windows Defender. However, that shouldn't be taking up 10.9/16GB of my RAM right away when I start up my computer.
| OS: Windows 10 |
I would try looking for a alternative antivirus as it seems wonky (as usual).
First of all, let try to see if there any malware are active running on your machine. Please run these following tools with no browsers or any applications running in order to prevent it escape through the internet.
Malwarebytes Anti Malware - For malware.
AdwCleaner - For adware, PUPS, and browsers hijacker.
Norton Power Eraser - For malware
HitmanPro 3 - For malware
ESET Online Scanner - For malware
Kaspersky TDSSKiller - For rootkit
Its a brand new install of the OS. Its hard to believe that there would be any malware on a clean, legitimate install.
| OS: Windows 10 |
So what I have come to realize is that my RAM isn't clearing. It just keeps stacking on memory. Even when I turn off my computer for the night, the previous memory isn't discharged. Also, if I try to take the sticks of RAM out, and put it back in the same slots after 3 minutes, the memory isn't discharged then either. Please help!
| OS: Windows 10 |
Windows Key + R
system32.dll
Enter Key
That should clear currently unused memory.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Windows Key + R
system32.dll
Enter Key
I'm getting this error. What do I do?
| OS: Windows 10 |
My mistake! It's "rundll32.exe" , not "system32.dll" !
I did rundll32.exe and it didn't clear the RAM. Am I just supposed to run it? Or am I supposed to restart my PC as well?
| OS: Windows 10 |
I did rundll32.exe and it down't clear the RAM.
It should clear all RAM cache.
Can you screenshot your Task Manager?
Please follow your own topics.
| OS: Windows 10 |
It looks like you have some malware or a rootkit on your PC. Are you comfortable with a clean install?
I am fine with a clean install. However, I'm not sure how there can be malware, since this computer was a clean install about 3 days ago. Is there a chance that its an issue with the Windows 10 boot drive that I got from Best Buy?
| OS: Windows 10 |
No. Restart the PC and screenshot your RAM usage after booting. Also, did you disable useless programs in your Start folder?
I disabled most of the useless programs. And here are the images of Task Manager immediately on startup. That is after I shut off the computer for about an hour.
| OS: Windows 10 |
Your Windows AntiMalware is acting up. It should not even be consuming 10MB of RAM. When it take that much, you have a virus or rootkit or something. Have you torrented any programs lately?
Haven't torrented anything on this. This rig has only been running for about 4 days, and in that time, all I have downloaded is Steam, 6 items from my Steam library, Battle.net and the games I have coinciding with Battle.net, as well as League of Legends.
| OS: Windows 10 |
