Yes an H60 would fit in that case. What CPU do you have?
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/481788-cpu-cooler/#findComment-6462787
i'd never recommend a 120mm AIO to anybody, Air just does it better for less, things like the Cyrorig H7.
to answer your original question it will fit in any 120mm fan slot.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/481788-cpu-cooler/#findComment-6462796
Yes, It would fit easily.
Thanks, and I have the 3770k
https://linustechtips.com/topic/481788-cpu-cooler/#findComment-6462806
There is always aesthetics though. Look at the Cooler Master Seidon 120V, if it was on sale for 40 bucks I would definitely buy it.
https://linustechtips.com/topic/481788-cpu-cooler/#findComment-6462881
If you don't plan on overclocking you really dont need a liquid cooler like that to be honest :)
https://linustechtips.com/topic/481788-cpu-cooler/#findComment-6462894
