can anyone help me figure out why i have a NullPointerException? thanks
import java.io.*;
public class NameSearchProgram {
  public static final int MAX_NAMES = 90000;
  public static int         numNames;
  public static String[]    names = new String[MAX_NAMES];
  // BubbleSort algorithm to sort all names by their length
  public static void bubbleSortByLength() {
    // ... Complete this ..
    for(int p=0; p < names.length; p++){
      if(names[p]==null){
        names[p]="expceptionNotFound";
        String storeName;
        for (int i=0; i<(names.length); i++){
          for(int j=0; j<(names.length); j++){
            if(names.length() > names[i+1].length()){
              storeName = names;
              names = names[i+1];
              names[i+1] = storeName;
Lenovo Y50-70 Touch
I7-4700
GTX-860M 2gb
https://linustechtips.com/topic/481468-java-help/
When you do
You declare an array , but you do not instantiate its elements , which remain null.
You need to initialize the array elements.
https://linustechtips.com/topic/481468-java-help/#findComment-6458502
When you do
woops sorry later on in the code it takes the string array from a txt file
Lenovo Y50-70 Touch
I7-4700
GTX-860M 2gb
https://linustechtips.com/topic/481468-java-help/#findComment-6458763
You should learn how to debug Java programs. When you're starting out with a new language you are going to run into a lot of problems like the one you just hit. Knowing how to debug your application will make solving your issues a lot faster and easier. Take a look at this: http://www.vogella.com/tutorials/EclipseDebugging/article.html
But to help with your question:
Lets add some strings to your names array and walk through bubbleSortByLength().
Lets say names contains a single name "Linus".
public static void bubbleSortByLength() {    // ... Complete this ..    for (int p = 0; p < names.length; p++) {        if (names[p] == null) {            names[p] = "expceptionNotFound";            String storeName;            for (int i = 0; i < (names.length); i++) {                for (int j = 0; j < (names.length); j++) {                    if (names[i].length() > names[i + 1].length()) { // i = 0, names[0] = "Linus", names[0 + 1] = null. You are trying to get the length() of a null string. That's what is causing your NullPointerException                        storeName = names[i];                        names[i] = names[i + 1];                        names[i + 1] = storeName;                    }                }            }        }    }}
https://linustechtips.com/topic/481468-java-help/#findComment-6459849
