Im sry if i put this in the wrong topic
Hai im new to building gaming pc and would like some help . I have two pc build in mind and would need some help with my final decision. Would appreciate if i can get help asap.
Build 1
ASUS AS H170 PRO GAMING i5-6600 3.3 GHZ
GTX950 STRIX 2GB
SEAGATE 1TB 7200R 64M SATA3
DDR4 HyperX 2400Mhz CL15 KIT 8GB
SEASONIC M12II-520 80+ Bronz/Modular
NZXT S340 Razer Edition
SP120 Green High Static Pressure × 2
Build 2.
i5 6500 gigabyte b150m-d3h. Kingston HyperX 8gb kit.
gigabyte gtx 960 4gb oc.
Samsung 850 Evo 250gb m.2 ssd. wd 1tb blue.
Samsung 24x dvdrw.
superflower leadex 550w silver. coolermaster n200 case.
nidec gentle typhoon fan.
Im gonna use them to play most of the mainstream games and the upcomong fallout 4
Thanks :")
( i do not whish to change any parts )
https://linustechtips.com/topic/481134-my-first-build/
Hai im new to building gaming pc and would like some help . I have two pc build in mind and would need some help with my final decision. .Would appreciate if i can get help asap
Build 1
GTX950 STRIX 2GB
Build 2.
Samsung 24x dvdrw.
Thanks :")
I don't understand what you want.  If you want me to tell you the build is good, I don't know if I can.
1.  Where are you buying this?  What country?
2.  What is your budget?
I see things that you are overspending on, I just don't know how much.
https://linustechtips.com/topic/481134-my-first-build/#findComment-6454436
NO. Dude! You dont buy a I5-6600 with an cheap ass GTX 950. Spend less on the  CPU and get a better GPU.
Oh. I overread the 2nd build :D      Way better.       But if you really want the I5-6600 you probably will need DDR4, which is expensive as ****.
If you're on a budget, i would go with a CPU from last GEN - maybe an i5 4670K - and a GTX 970.
Student - Budgetbuilder - trying to save as much money as possible :D    | I love clean Setups |
 PC: i5-3470. GTX660. 8GB DDR3. -> 320 USD  | Z3 -> 160USD | selfbuild Speakersystem -> 21USD
https://linustechtips.com/topic/481134-my-first-build/#findComment-6454446
DDR4 is nearly the same price as DDR3 :P And 4690k + R9 390 is better as the 390 performs the same or slightly better.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/481134-my-first-build/#findComment-6454752
@TheRandomness it is pre build because they built it for someone else but that person never showed up so im getting either one at a cheaper price
In that case, go for build 2. Better graphics card and has an SSD. ;)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/481134-my-first-build/#findComment-6456595
Sry for puting this at the wrong topic , its my 2nd time here.
No, no bro I'm the one that should apologize, I was on mobile last night and did not notice that you were new to the forum. My apologies to you.
Also welcome to the LTT forum community :)
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/481134-my-first-build/#findComment-6458184
