Different build comparisons
Solved by ThinkWithPortals,
-snip-
I reckon the original is the best. You won't need an i7 for gaming. You might want to add more storage however, as I think you'll find 250GB is not enough. A Seagate Barracuda 2TB should do nicely. You could do with 16GB RAM also, because it's cheap nowadays.
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
play_circle_filled
Latest From ShortCircuit:
