Well, you can install it straight away, connect the SLI bridge and set the drivers...
There are 2 possibilities
a) It works alright
b) it does not, and you need to check the new GPU on its own.
Make sure to have the latest drivers installed. The Nvidia Experience app will make your life simpler if you are using nVidia cards.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
