Overclocking Voltage
Solved by Patrick Bateman,
Hi,
I just OC'd my 4770K to 4.3GHz (I know it's not much, I just wanted a little bit more from it, don't really need anything more).
I set the voltage to auto after the OC but the problem is that when running Aida64 the voltage rockets up to 1.5V, causing it to throttle. Even in CS:GO it sat at 1.392V but didn't throttle.
Is there a setting I might have missed?
Thanks!
avoid auto voltage. set it manually. and when stressing make sure its manual vcore mode.
