Well you're on AM3+ so you're basically locked into ATX unless you are fine with a really bad motherboard that could catch fire.
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6439577
Is the ASRock 970M Pro3 AM3+/AM3 AMD 970 a good motherboard
nope
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6439600
ASUS M5A78L-M/USB3 Is a decent AM3+ board
It really isn't.
@Prismo_ that board is passable but doesn't really give me a feeling of reliability due to the weak VRM.. I'd still just go ATX where you can get much better boards and have a better experience.
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6439707
It really isn't.
You've had it and had problems with it??????
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6440105
I know of problems people have had with it. I have its older (literally) brother the M4A78LT-M which minus USB3.0 is a very similar board hardware wise and it is really not a board for 8 cores or high end machines at all. It's a cheap office/home PC board for people who wanted integrated graphics in 2008 before APUs were a thing.
Tell me what's decent about 760G (2008), no SATA6GB/s, no USB3.0 front panel, non-UEFI bios (so rip fast boot and large capacity hdds). Not to mention the unheatsinked 4+1 VRM which is documented to throttle and cannot maintain any turbo function under a consistent level of load.
None of that constitutes to decent in 2015.
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6440297
You can't compare things being decent " in 2015 " when the AM3+ platform is from 2011.
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6440320
And the 760G platform is from 2008 so its not decent whichever way you look at it.
There are boards on the AM3+ platform that still qualify as decent; they don't fit in the mATX bracket however.
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6440572
Yep^^ Ive dealt with 4-5 burned up AM3+ boards, and all of them were budget mATX offerings.
Stick to the good stuff and go full atx or upgrade to a different platform, if you love AMD wait for the upcoming AM4 socket :D @Prismo_
https://linustechtips.com/topic/480043-matx-vs-atx/#findComment-6440595
