Graphics card not installing properly
Go to solution Solved by Ookami,
Dunno if its still working, but you can try to force nvidia drivers:
Copy&Pasted it from http://www.overclock.net/t/470312/182-x-drivers-force-install-to-notebook
1. Download the latest nVidia GeForce X Series graphics drivers (of cource download drivers for your card not the X series)
2. Run the set-up program
3. The set-up program will fail, this is normal
4. Go to Device Manager (right click Computer and select Manage > Device Manager)
5. Expand the Display adapter
6. Right click on your GPU
7. Click Properties
8. Click the Driver tab
9. Click on "Update Driver"
10. Click on "Browse my computer for driver software"
11. Click "Let me pick from a list of device drivers on my computer"
12. Click on "Have Disk" button
13. Click Browse
14. Browse to the folder at c:\\NVIDIA\\WinVista\\1xx.xx\\English\\ (where 1xx.xx is the version you just downloaded in step 1)
15. Click on the file named nv_disp.inf and click Okay, then click Next.
16. Select the video card closest to what you have
17. It will tell you that the driver is not digitally signed, ignore this notice.
18. If everything works, you should have latest nVidia drivers for your notebook.
Also a guy at Overclocked posted if your motherboard BIOS is up to date because till he didnt install the BIOS update he also had problems.
hi, this is one of my first posts on this forum, i have posted my problem on another forum, and they haven't got the answer so far, so instead of retyping everything, im going to link you to the thread to read as it may be easier.
http://forum.overclock3d.net/showthread.php?t=56083&page=1
https://linustechtips.com/topic/47893-graphics-card-not-installing-properly/
Try to clean the driver with DriverSweeper delete the ALL Nvidia based drivers and restart the PC then install again. Also about it running it on iGPU there should be setting to use only dedicated graphic card.
<p>Eryi's Action Rule#2 - "Dont jump on the green mushroom"
Ministry of StopIt!
7. Click Properties
13. Click Browse
Ministry of StopIt!
