Either take the top panel out and install the rad or take the motherboard out.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413213
rad wont fit on top of case
Then mount it in the front.
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413297
When i try to install my radiator in my h440 i cant install it because the mobo is in the way. How can i fix this
If I remember correctly the fans on a 280mm top mounted h440 have to go on the outside of the top panel.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413340
Ive tried that but how do i put the top panel back on?
uhh... Ideally your fans aren't as thick and it just fits on... IDK what to do if the fans are thicker than the top panel.
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413364
There is some foam on the top panel so yea
Just rip that out. The foam doesn't matter and only hurts airflow in regular situations anyways. lol.
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413403
You can't really put the fan on the outside of an H440 the top doesn't have enough thickness to house the fan especially since the fan mounts on the H440 are bumped out for more room inside the case.
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413410
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413440
my bad then. ignore my comment about ripping the foam.
But @op check out the link here, the dude apparently got it to fit.
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413442
Yeah the X61 does seem to work no problem as long as long as your heatsinks aren't extending off the board which would be weird:
https://www.flickr.com/photos/minthu/15713312851/in/album-72157649131895841/
https://linustechtips.com/topic/478642-installing-280mm-fans/#findComment-6413460
